Einleitung
Disassembling the Hipstreet Titan 2 HD cover is a simple 5-10 minute process that is essential to fixing any component in the device.
Was du brauchst
Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
Insert the plastic opening tool between the screen cover and rear cover of the tablet.
Grasp the small suction cup.
Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
Pull upward on the small suction cup handle while sliding the opening tool.
Congratulations your tear down is complete. To reassemble your device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
