Einleitung
Use this guide to replace the speaker. First you'll need to remove the rear cover. This can be a difficult process.
Was du brauchst
Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
Insert the plastic opening tool between the screen cover and rear cover of the tablet.
Grasp the small suction cup.
Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
Pull upward on the small suction cup handle while sliding the opening tool.
Using a #PH000 screwdriver, remove the three 0.145in circuit board placement screws.
Lift the hinge locks on the three ribbon connectors and disconnect the ribbon connectors.
Using a solder removal tool, remove the speaker soldered connectors.
Solder the new speaker wire connections to circuit board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
