Einleitung
This motherboard replacement guide will walk you through the steps on how to remove necessary components in order to get to the motherboard. Replacing the motherboard is a moderate, four-step process using necessary tools, including a soldering iron.
Was du brauchst
Use the plastic opening tools to pry the screen from the back of the device.
Use the spudger to release three (3) black clips connecting the components to the motherboard.
Use the soldering iron to heat the end of the wires connecting the speaker to the motherboard.
Apply heat until the wires are free.
Using the soldering iron, apply heat to the end of the wires until they are free from the motherboard.
Now that the battery and speaker are removed, the black clips are undone, and the motherboard is unscrewed, remove the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
