Einleitung
If your Chromebook C11 battery is not holding its charge, dies to quickly, or doesn’t charge at all this is a sign to replace the battery. Replacing the battery on your Chromebook C11 is a simple process, and is a great way to make it run like new again. If the battery has swollen you can follow this link for more information.
A good safety tip is to make sure you have a static discharge while working with the computer and its components, also be sure to shutdown and make sure the laptop has no power before starting this process.
There are no special skills needed to replace the battery, As long as the user knows how to use a screwdriver and tweezers. Replacing the battery will help your Chromebook C11 run more efficiently. This guide demonstrates how to properly remove and replace the battery on a Hisense Chromebook C11.
Was du brauchst
Remove the front two hub caps.
When finished, you should be able to remove the back cover.
Pry the perimeter of the case open with the plastic opening tool.
Remove the back panel.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Thank you! Andrew Beiler IBM Research New York
Hola mi chome prende pero aparece un recuadro que dice error no esta instalado el chrome os
Cuanto cuesta la bateria estoy dispuesto a pagar 20 dlls por ella si es nesesario
