Zum Hauptinhalt wechseln
Hisense Sero 7 Pro Battery Replacement
Was du brauchst
  1. Hisense Sero 7 Pro Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Hisense Sero 7 Pro Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Battery Replacement: Schritt 2, Bild 1 von 2 Hisense Sero 7 Pro Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Battery Replacement: Schritt 3, Bild 1 von 2 Hisense Sero 7 Pro Battery Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
Abschluss
Baochau Nguyen
314 Reputation
3 Anleitungen geschrieben
Texas Tech, Team 38-2, Bennett Fall 2016 Mitglied von Texas Tech, Team 38-2, Bennett Fall 2016
TTU-BENNETT-F16S38G2
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
would be nice to actually have replacement battery avaible to buy new battery
howlingwolff10 - Antwort
Where could one buy new battery?
Joshua Wood - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 2,682
