Einleitung
Replacing the front camera can be completed in just a few minutes of time with a plastic pry tool.
Was du brauchst
Using a plastic opening tool, pry open the back cover from the tablet.
Using the pry tool, pry up the front facing camera.
Use a plastic opening tool to detach the front camera ribbon cable from the press-fit connector. Put the opening tool under the edge of the connector and gently pop it up.
Fast fertig!
Abschluss
