Einleitung
If you are experiencing issues with the camera on your Hisense Sero 8 device due to prolonged use, you can fix it by replacing the front and back camera sets. This guide will help you to repair the camera set. Before you begin, please check the troubleshooting guide to see the symptoms of your device.
Was du brauchst
Use an opening tool to pry open a corner of the device, then slide the tool down the side of the device to completely open it.
Use the pointed end of the spudger to lift the camera from the motherboard.
Use tweezers to carefully pull out the camera set.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
