Zum Hauptinhalt wechseln
Hitachi CP-X440 Motherboard Replacement
Was du brauchst
  1. Hitachi CP-X440 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Turn the projector upside down so the bottom is facing up.
    • Remove the 6 black 2 cm screws with a Phillips #1 Screwdriver.
    • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
  2. Hitachi CP-X440 Motherboard Replacement: Schritt 2, Bild 1 von 2 Hitachi CP-X440 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Flip the projector right-side up and navigate to the back panel.
    • Remove the 3 black, 1 cm screws on the back panel with a Phillips #1 Screwdriver.
    • Remove the two silver 1 cm screws on the power switch panel with a Phillips #1 Screwdriver.
  3. Hitachi CP-X440 Motherboard Replacement: Schritt 3, Bild 1 von 2 Hitachi CP-X440 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Now turn the projector so the front is facing you.
    • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
  4. Hitachi CP-X440 Motherboard Replacement: Schritt 4, Bild 1 von 2 Hitachi CP-X440 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Gently remove the cables from their white connectors on the circuit board.
  5. Hitachi CP-X440 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Gently pull out the three orange ribbons from their white connectors on the circuit board.
    • You can use a spudger tool to pry them out of place.
  6. Hitachi CP-X440 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the 5 silver 0.5 cm screws on the circuit board with a Phillips #2 Screwdriver.
  7. Hitachi CP-X440 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the motherboard so the projector is exposed.
Abschluss
Abby Myers
294 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 139
