Einleitung
This guide will show you how to disassemble the projector acting as a supplemental guide for the other replacement guides for this device. Many of the parts that may need replacing in the projector require the device to be disassembled.
Before beginning disassembly, be sure the projector is unplugged from any outlets.
Was du brauchst
Turn the projector upside down so the bottom is facing up.
Remove the 6 black 2 cm screws with a Phillips #1 Screwdriver.
Flip the projector right-side up and navigate to the back panel.
Remove the 3 black, 1 cm screws on the back panel with a Phillips #1 Screwdriver.
Remove the two silver 1 cm screws on the power switch panel with a Phillips #1 Screwdriver.
Now turn the projector so the front is facing you.
Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
Gently pull out the three orange ribbons from their white connectors on the circuit board.
You can use a spudger tool to pry them out of place.
Remove the 5 silver 0.5 cm screws on the circuit board with a Phillips #2 Screwdriver.
