Zum Hauptinhalt wechseln
Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
Was du brauchst
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: Schritt 1, Bild 1 von 1
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: Schritt 2, Bild 1 von 1
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: Schritt 3, Bild 1 von 1
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
Abschluss
Mike
397 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 9-2, Banghart Winter 2017 Mitglied von Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 404
