Zum Hauptinhalt wechseln
HoMedics TotalComfort UHE-CM18 Control Panel Replacement
Was du brauchst
  1. HoMedics TotalComfort UHE-CM18 Control Panel Replacement, Control Panel: Schritt 1, Bild 1 von 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement, Control Panel: Schritt 1, Bild 2 von 2
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 2, Bild 1 von 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 3, Bild 1 von 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 3, Bild 2 von 2
    • Remove the remaining four 7mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 4, Bild 1 von 3 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 4, Bild 2 von 3 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the two white cables by pushing down the center tab at the end and pulling it out of its socket.
  5. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 5, Bild 1 von 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: Schritt 5, Bild 2 von 2
    • Remove the three 7mm screws that attach the control panel to the case.
    • Remove the control panel from the case.
Abschluss
Johny
557 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 146
