Einleitung
If your humidifier seems to not be turning on, follow this guide to access the power supply board. This guide is an easy-to-follow process of how to remove your power supply board for a replacement. For this guide, you will use a Phillips #1 screwdriver head to remove and replace your power supply board.
Was du brauchst
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
Remove the AC power plug cover.
Remove the remaining four 7 mm screws that hold the bottom cover.
Remove the bottom cover.
Disconnect the two cables with the red and white ends by pushing down the center tab at the end and pulling them out of their sockets.
