Zum Hauptinhalt wechseln
Holley 4 Barrel Carburetor Gasket Replacement
Was du brauchst
    1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: Schritt 1, Bild 1 von 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: Schritt 1, Bild 2 von 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: Schritt 1, Bild 3 von 3
      • Make sure your carburetor has no fuel inside.
      Frag FixBot
      Kommentar hinzufügen
    2. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 2, Bild 1 von 1
      • Remove the four 47 mm flat head screws.
      Frag FixBot
    3. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 3, Bild 1 von 1
      • Remove the bowl from the side of the carburetor.
      Frag FixBot
    4. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 4, Bild 1 von 1
      • Remove the four 63 mm flat head screws.
      Frag FixBot
    5. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 5, Bild 1 von 1
      • Remove the bowl and the steel fuel line from the side of the carburetor.
      Frag FixBot
    6. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 6, Bild 1 von 2 Holley 4 Barrel Carburetor Gasket Replacement: Schritt 6, Bild 2 von 2
      • Remove the spacer from the side of the carburetor.
      • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
      Frag FixBot
    7. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 7, Bild 1 von 1
      • Remove the six 2.5 mm hex screws from the secondary metering block.
      • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
      Frag FixBot
    8. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 8, Bild 1 von 1
      • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
      Frag FixBot
    9. Holley 4 Barrel Carburetor Gasket Replacement: Schritt 9, Bild 1 von 2 Holley 4 Barrel Carburetor Gasket Replacement: Schritt 9, Bild 2 von 2
      • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
      • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
      Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 34
Letzte 30 Tage: 102
Insgesamt: 5,681
