Einleitung
If you are having trouble trying to figure out how to replace a fan blade? Then coming to the right person to help if the only good way to go. With this guide, I will go through step by step instructions on how to replace the blade in various easy steps.
Was du brauchst
In the marker, we have the screw that connects the fan to the box. Now using your tool, remove six 2mm Phillips #2 screws.
Next remove four 2mm screws on the blade itself, that holds the fan in place. So that way we can remove the fan out of the box.
This fan blade will be removed and the new one will be replaced. The fan blade can be popped off. Once done, place the new one back on.
Put the screws back inside to make sure the fan doesn't pop out of the box and harm anyone.
Keep screwing in the rest of your screws into the fan before continuing on the last step.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Wow, the step with removing the motor from it’s mount of the 4 screws is totally unnecessary! You obviously have not done these too often — all you have to do is to remove the FRONT fan shroud, and then pull the fan blade (or what’s left of it if replacing) from the front of the motor! WAY too much work with how you explained it here!
