Einleitung
Repair or replace your Holmes HEH8031 heater circuit board.
Was du brauchst
Turn heater over so the controls are facing up.
Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
Remove four 12mm Phillips #2 screws from the circuit board.
Desolder the BLACK wires from the "AC-L" point and "T/S" point.
Desolder the WHITE wire from the "AC-N" point.
Desolder the RED wire from the "FAN-RED".
Desolder the GREY wire from the "24V" point.
Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
