Zum Hauptinhalt wechseln
Holmes HEH8031 Control Buttons Replacement
Was du brauchst
  1. Holmes HEH8031 Control Buttons Replacement, Housing: Schritt 1, Bild 1 von 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: Schritt 2, Bild 1 von 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: Schritt 3, Bild 1 von 2 Holmes HEH8031 Control Buttons Replacement: Schritt 3, Bild 2 von 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: Schritt 4, Bild 1 von 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: Schritt 5, Bild 1 von 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: Schritt 5, Bild 2 von 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: Schritt 5, Bild 3 von 3
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: Schritt 6, Bild 1 von 3 Holmes HEH8031 Control Buttons Replacement: Schritt 6, Bild 2 von 3 Holmes HEH8031 Control Buttons Replacement: Schritt 6, Bild 3 von 3
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Chris Shaffer
255 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-1, Baechle Fall 2016 Mitglied von IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 7
Insgesamt: 418
