Einleitung
Use this repair if you want to replace your fan blade assembly. Be sure to turn off the power and unplug the heater before beginning to change the fan assembly. The screws in this heater are recessed, so using a magnetic screwdriver will be helpful. Note: When reassembling the unit, you must replace the 2 machine screws that connect the rotor assembly to the housing before replacing the coarse-threaded screws. Aligning the machine screws may take some finesse.
Was du brauchst
Identify that you have the Holmes HEH8031 heater. The model number is on the bottom of the unit.
Place the heater so the rear housing is facing you.
Remove the eight (8) 1 cm coarse-threaded screws around the perimeter.
Remove the two (2) 7 mm machine screws in the center.
Turn the fan blade assembly over so blades are facing up.
Locate the four (4) metal tabs that connect the blade assembly to the rotor.
Using the pointed metal spudger, bend each of the four (4) metal tabs toward the rotor shaft.
