Zum Hauptinhalt wechseln
Holmes HEH8031 Safety Weight Replacement
Was du brauchst
  1. Holmes HEH8031 Safety Weight Replacement, Housing: Schritt 1, Bild 1 von 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: Schritt 2, Bild 1 von 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: Schritt 3, Bild 1 von 2 Holmes HEH8031 Safety Weight Replacement: Schritt 3, Bild 2 von 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: Schritt 4, Bild 1 von 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: Schritt 5, Bild 1 von 2 Holmes HEH8031 Safety Weight Replacement, Safety Weight: Schritt 5, Bild 2 von 2
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
Abschluss
Deanna Jack
333 Reputation
4 Anleitungen geschrieben
IUPUI, Team 2-1, Baechle Fall 2016 Mitglied von IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 535
