Einleitung
If the water in your device's container smells bad, follow this guide to replace the water inside the container with clean and fresh water. For this guide you will need some sort of towel or cleaning device to clean the container.
Was du brauchst
Unscrew the container from the lid.
Turn the cap counterclockwise and gently remove the lid from the container.
Remove the water that is already in the container and dump the old water into safe water disposal area.
Dump the old water outside or down the sink.
Clean out the container.
Use a towel, some soap, and water to clean out the container.
Take the damp towel and move it along all off the container and then rinse it out with water.
Fill the container with fresh water.
Take some room temperature water from the sink and pour it into the clean container.
