Einleitung
If you are having problems turning on the shear or the operating switch seems too loose, this guide might be useful for replacing the part.
Was du brauchst
Use a Philips-head screwdriver to remove the six, 15 mm screws from the casing.
Remove the faceplate from the main body of the device, lift it and expose the inner mechanisms.
Fast fertig!
Abschluss
