Zum Hauptinhalt wechseln
Homelite UT44172 Plastic Casing Replacement
Was du brauchst
  1. Homelite UT44172 Plastic Casing Replacement, Opening Device: Schritt 1, Bild 1 von 1
    • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
  2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: Schritt 2, Bild 1 von 2 Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: Schritt 2, Bild 2 von 2
    • Pull the faceplate away from the body of the device and replace it with the new faceplate.
    • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
    • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
Abschluss
Adam soto
301 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 17-5, Watkins Winter 2015 Mitglied von USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 206
