Zum Hauptinhalt wechseln
Homelite UT44172 Safety Switch Replacement
Was du brauchst
  1. Homelite UT44172 Safety Switch Replacement, Opening the device: Schritt 1, Bild 1 von 1
    • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
  2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: Schritt 2, Bild 1 von 1
    • Remove the faceplate to expose the inner mechanisms.
  3. Homelite UT44172 Safety Switch Replacement, Switch Removal: Schritt 3, Bild 1 von 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: Schritt 3, Bild 2 von 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: Schritt 3, Bild 3 von 3
    • Remove the safety switch by pulling it away from the body of device.
    • Be careful not to lose the spring, which is under pressure and may fly out during removal.
  4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: Schritt 4, Bild 1 von 1
    • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
    • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
Abschluss
Daniel Endericavillacis
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 17-5, Watkins Winter 2015 Mitglied von USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 327
