Einleitung
This guide shows how to remove and replace the rotor for the Honda EU3000IS1AWK 3000 watt generator.
You will need the following specialty tools in order to complete this guide:
- Flywheel puller kit with metric bolts (in order to remove the rotor)
- Long shaft (at least 5 inches) Phillips #1 screwdriver
Be sure to drain the fuel tank before you begin this guide, and have containers at hand to catch any fuel spillage.
Some images in this guide may show minor discontinuities. They should not affect the overall guide procedure.
Was du brauchst
Use a large flathead screwdriver to unlock the maintenance cover.
Open the maintenance cover.
Use a Phillips screwdriver to remove the screw securing the spark plug cover.
Remove the spark plug cover.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Carefully tilt the generator to its side or back.
Use a 10 mm socket to remove the two nuts securing the front bushing mounts to the bottom of the generator.
Carefully tilt the generator back to an upright position.
Unlatch the four clips securing the air cleaner cover.
Remove the air cleaner cover.
Pull and disconnect the breather tube from the top corner of the air cleaner housing.
Pull and disconnect the lower tube from the bottom corner of the air cleaner housing.
Use a 10 mm socket to remove the three fasteners securing the air cleaner housing:
Two 10 mm nuts
One 10 mm bolt
Use a flathead screwdriver to pry and unclip the tube from the air cleaner housing.
Use a 10 mm socket to remove the four capped nuts securing the front cover.
Remove the front cover.
Use a 10 mm socket to remove the four bolts securing the handle to the frame.
Use an 8 mm socket to disconnect the battery wires from the battery terminals.
Disconnect the black negative cable first to prevent the risk of shorting the battery.
Use a 10 mm socket to remove the four capped nuts securing the lower plate.
Remove the lower plate.
Insert a flathead screwdriver into the top of the brown fuse clip in order to release the fuse holder.
Detach the fuse holder from the brown clip.
Use pliers to lift and disconnect the choke cable from the choke stay.
Use a long shaft Phillips screwdriver to remove the deeply recessed screw securing the fuel cutoff switch.
Use a 10 mm socket to remove the four bolts securing the control panel.
Remove the following bolts securing the inverter:
One 8 mm ground bolt
Three 10 mm bolts (one behind the control panel)
Reach behind the inverter along the edges and disconnect the six connectors from the back of the inverter.
The third image shows the locations of all six sockets on the inverter.
Use a screwdriver to push the metal collar out of the center of the rubber mount.
Squeeze the mount and remove it from the inverter.
Repeat the procedure with the remaining mounts and transfer them to the replacement inverter.
Use a 10 mm socket to remove the four capped nuts securing the rear cover.
Remove the rear cover.
Use a 10 mm socket to remove the four bolts securing the muffler protector.
Remove the muffler protector.
Pull the muffler shroud slightly away from the frame to access the top frame bolts.
Use a 10 mm socket to remove the two bolts securing the top edge of the cover.
Use a 10 mm socket to remove the three bolts securing the front edge of the cover.
Use a 10 mm socket to remove the four bolts from the maintenance cover side.
Remove the maintenance cover.
Use an 8 mm socket to remove the two bolts securing the non-access side of the cover.
Lift the cover up slightly to free it from the frame and slide it back by a few inches.
At this point, it may be helpful to temporarily re-attach the control panel back onto the front frame with some 10 mm bolts.
Lift up and release the choke cable's rubber bushing from the choke stay.
Use a 10 mm socket to remove the three frame bolts securing the bottom of the front frame.
Use a 10 mm socket to remove the four bolts securing the top of the front frame.
Pull and disconnect the starter motor's black barrel and white barrel connectors.
Unplug the four-wire regulator connector from the bottom edge of the control panel.
Insert the edge of a large flathead screwdriver under the bottom edge of the front frame.
Pry up and outward to release the bottom edge of the front frame.
Use a 10 mm socket to remove the three bolts securing the recoil starter.
Remove the recoil starter and move it out of the way.
Be careful not to lose the metal collar in each of the recoil starter's bolt holes.
Use a 10 mm socket to remove the two bolts securing the starter pulley.
Remove the starter pulley.
Use a 10 mm socket to remove the bolt securing the air cleaner housing bracket.
Remove the air cleaner housing bracket.
Use pliers to squeeze and loosen the hose clamp securing the carburetor fuel line.
Pull and disconnect the carburetor fuel line from the petcock assembly.
Use a large crescent wrench to loosen the petcock assembly from the fuel tank.
Remove the petcock assembly.
Place a container below the carburetor drain tube to catch the excess fuel.
The carburetor drain screw is located at the bottom of the carburetor.
Use a flathead screwdriver to loosen the brass fuel drain screw until fuel begins to drain out of the carburetor.
Once you drain the fuel bowl, re-tighten the fuel drain screw.
Disconnect the throttle control connector from the top of the carburetor.
Unwrap the throttle control wires from the carburetor.
Use a 10 mm socket to remove the seven bolts securing the fan cover:
Four bolts on top
One recessed bolt in the bottom left corner
Two bolts in the bottom right corner
Insert a pry bar underneath the fan cover.
Pry upwards to lift the generator assembly slightly.
As you lift the generator assembly with the pry bar, maneuver and remove the two generator mounts from their recess.
Use a 19 mm socket to remove the nut securing the rotor to the generator shaft.
Attach a flywheel puller to the rotor and use it to loosen the rotor.
To prevent the rotor from spinning, insert a flathead screwdriver into one of the rotor slots and brace it against the ignition coil bracket.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
