Einleitung
Replacing an air filter is a common task every car owner will likely need to complete at some point in their lives. If you haven’t replaced your air filter in quite some time, or if a mechanic tells you that your air filter is in need of replacement, don’t fret! This is a repair you can easily complete yourself. Replacing the air filter will improve the air quality inside your cabin.
Was du brauchst
Ensure that your 2016 Honda CR-V Touring Edition is off.
Open the glovebox and remove all of its contents.
Unfasten the hinge on the right side of your glovebox so the hook-part of the hinge is free and clear.
Push both sides of the glovebox together while lowering until the glovebox hangs at its lowest point.
Grasp both clasps on either side of the rectangular cabin air filter protective cover and pull to release the cover.
Insert the new filter, taking care to orient the filter in the correct direction for airflow.
Place the cabin air filter protective cover over top of the filter until you hear audible clicks from the clasps engaging.
Push the glovebox up until you feel a detent where it is self supported but is not fully in the up-position.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
