Zum Hauptinhalt wechseln
Honda CSC29 Brushes Replacement
Was du brauchst
  1. Honda CSC29 Brushes Replacement, Alternator Front Cover: Schritt 1, Bild 1 von 3 Honda CSC29 Brushes Replacement, Alternator Front Cover: Schritt 1, Bild 2 von 3 Honda CSC29 Brushes Replacement, Alternator Front Cover: Schritt 1, Bild 3 von 3
    • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
    • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
    • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
  2. Honda CSC29 Brushes Replacement: Schritt 2, Bild 1 von 3 Honda CSC29 Brushes Replacement: Schritt 2, Bild 2 von 3 Honda CSC29 Brushes Replacement: Schritt 2, Bild 3 von 3
    • Pull cover off the body of the alternator
    • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
  3. Honda CSC29 Brushes Replacement, Brushes: Schritt 3, Bild 1 von 3 Honda CSC29 Brushes Replacement, Brushes: Schritt 3, Bild 2 von 3 Honda CSC29 Brushes Replacement, Brushes: Schritt 3, Bild 3 von 3
    • You should now be able to see the recifier assembly, the brushes are located in the middle of the recifier assembly.
    • Remove the brush assembly by unscrewing 2, 6mm center screws using a #2 Phillips head screw driver
  4. Honda CSC29 Brushes Replacement: Schritt 4, Bild 1 von 3 Honda CSC29 Brushes Replacement: Schritt 4, Bild 2 von 3 Honda CSC29 Brushes Replacement: Schritt 4, Bild 3 von 3
    • Remove the brush assembly by pulling it out.
  5. Honda CSC29 Brushes Replacement: Schritt 5, Bild 1 von 1
    • Inspect the brushes. If they are scored and not smooth you will need to replace the entire assembly.
    • When reinserting the brushes, make sure the springs keep the brushes in contact with the stator.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 25-1, Maness Spring 2016 Mitglied von Cal Poly, Team 25-1, Maness Spring 2016
CPSU-MANESS-S16S25G1
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 1,072
