Einleitung
Are you having issues with sluggish electrical components in your Honda? An issue with the Diode Trio on your Alternator's Rectifier Bridge will cause voltage to leak from your car battery, hampering its performance. The diodes act like one-way check valves, splitting AC current into a positive and negative branch that redirected to the positive and ground terminals of the car battery.
Was du brauchst
Pull cover off the body of the alternator
Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
With the alternator cover removed, use a #2 Phillips screwdriver to remove the two, 6 mm screws that hold the brush cover in place.
Remove the brush cover assembly from the alternator. You might need to insert a needle in the small hole to separate the brushes from the rotor. Pull it out without using much force to avoid damage.
Use a #2 Phillips screwdriver to remove the two 6mm screws holding down the voltage regulator
Locate the copper leads connecting the stator to the bridge assembly. There are 3 sets of 2 leads on the perimeter of the bridge, making 6 leads total.
Use wire cutters to cut all 6 of the leads on the perimeter of the bridge.
If necessary, use a pry bar to gently raise the top of the bridge assembly off the alternator
4 weitere Nutzer:innen haben diese Anleitung absolviert.
