Einleitung
Follow this guide to replace a damaged tine on the Honda FC600 tiller.
Was du brauchst
Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
Set down a block (or blocks) of wood onto your work surface.
Lift and roll the tiller over the wood block until the center of the tine axle is hovering over the wood block.
Gently set the tiller down so that the center of the tine axle rests on the wood block.
Place a block (or blocks) of wood under the tiller's drag bar to prevent the tiller from leaning back.
Remove the two 14 mm nuts securing the tine to the mounting bracket.
