Einleitung
Use this guide to replace the carburetor in a Honda Light Duty Tiller F220K1AT715492.
Make sure the gas switch on the carburetor is in the off (downward) position before you begin this procedure.
Drain the gas before you begin this procedure. Any remaining gas will spill out when you remove the carburetor fuel line. Be ready to contain any spillage.
Was du brauchst
Pull the spark plug connector straight off of the spark plug.
Push down on the two tabs at the top of the air filter cover.
With the two tabs depressed, swing the top of the cover down.
Remove the cover.
Use an 8 mm socket to remove the following fasteners securing the air cleaner housing:
Two silver nuts
One black bolt
Slide the pink breather tube out of its clip on the back of the air cleaner housing.
Use a flathead screwdriver to gently pry the black breather tube off of its connector on the back of the air cleaner housing.
Hold the black carburetor hose in place and rotate the air cleaner housing clockwise until you can slide the hose out of its slot on the air cleaner housing.
Remove the air cleaner housing.
Use a pair of pliers to pinch the tabs on the carburetor fuel hose clamp together, then slide the hose clamp about an inch down the fuel hose.
Pull the fuel hose straight down to slide it off of the carburetor's hose connector.
Rotate the small clip holding the governor rod on the governor arm clockwise.
With the clip out of the way, slide the governor rod out of the governor arm.
Slide the carburetor gasket 16221-ZG0-801 off of the carburetor bracket and remove it.
Use a Phillips #2 screwdriver to remove the two screws securing the carburetor bracket.
Remove the carburetor bracket, along with the carburetor nozzle and insulator plate.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
