Zum Hauptinhalt wechseln
Honeywell HT900C Motor Replacement
Was du brauchst
  1. Honeywell HT900C Motor Replacement, Motor: Schritt 1, Bild 1 von 3 Honeywell HT900C Motor Replacement, Motor: Schritt 1, Bild 2 von 3 Honeywell HT900C Motor Replacement, Motor: Schritt 1, Bild 3 von 3
    • Remove the six 15 mm screws securing the fan's frame to its outer ring on the back using a Phillips #1 screwdriver.
    • Due to the small size of the screw holes, a long and thin screwdriver may be necessary.
  2. Honeywell HT900C Motor Replacement: Schritt 2, Bild 1 von 3 Honeywell HT900C Motor Replacement: Schritt 2, Bild 2 von 3 Honeywell HT900C Motor Replacement: Schritt 2, Bild 3 von 3
    • To gain access to the fan's inner workings, gently pull the blade cover away from the main body.
  3. Honeywell HT900C Motor Replacement: Schritt 3, Bild 1 von 2 Honeywell HT900C Motor Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 36 mm screws from the metal plate located behind the blades using a Phillips #1 screwdriver.
    • The screws can be hard to remove so you may need to twist the screwdriver harder and screws can be removed easily.
  4. Honeywell HT900C Motor Replacement: Schritt 4, Bild 1 von 3 Honeywell HT900C Motor Replacement: Schritt 4, Bild 2 von 3 Honeywell HT900C Motor Replacement: Schritt 4, Bild 3 von 3
    • Carefully pull the motor it out of its resting position and tilt it forward to access the back of the motor.
  5. Honeywell HT900C Motor Replacement: Schritt 5, Bild 1 von 3 Honeywell HT900C Motor Replacement: Schritt 5, Bild 2 von 3 Honeywell HT900C Motor Replacement: Schritt 5, Bild 3 von 3
    • Remove two 10 mm screws from the motor's back using a Phillips #1 screwdriver.
  6. Honeywell HT900C Motor Replacement: Schritt 6, Bild 1 von 2 Honeywell HT900C Motor Replacement: Schritt 6, Bild 2 von 2
    • Remove the 20 mm screws beside the fan blade using a Phillips #1 screwdriver.
    • The screws are attached to two parts of the motor so it can easily fall off after removing the screws.
  7. Honeywell HT900C Motor Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the circular motor from the square holder.
    • The circular motor is still connected to the fan blades.
  8. Honeywell HT900C Motor Replacement: Schritt 8, Bild 1 von 2 Honeywell HT900C Motor Replacement: Schritt 8, Bild 2 von 2
    • Remove the metal washer from the axle.
  9. Honeywell HT900C Motor Replacement: Schritt 9, Bild 1 von 1
    • Replace the old motor with a new one, and you're done!
    • Using the lubricant to easily put the new motor back.
    • Always double-check that the screws are securely in place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Duy Anh Nguyen
169 Reputation
1 Anleitung geschrieben
York University, Team B-10, Allen Fall 2022 Mitglied von York University, Team B-10, Allen Fall 2022
YORK-ALLEN-F22SBG10
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 929
