Zum Hauptinhalt wechseln
Honeywell HY-204 Fan Motor Replacement
Was du brauchst
  1. Honeywell HY-204 Fan Motor Replacement, Case: Schritt 1, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement, Case: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Motor Replacement: Schritt 2, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement: Schritt 2, Bild 2 von 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Motor Replacement, Fan Blades: Schritt 3, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement, Fan Blades: Schritt 3, Bild 2 von 2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Motor Replacement: Schritt 4, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement: Schritt 4, Bild 2 von 2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  5. Honeywell HY-204 Fan Motor Replacement, Fan Motor: Schritt 5, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement, Fan Motor: Schritt 5, Bild 2 von 2
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  6. Honeywell HY-204 Fan Motor Replacement: Schritt 6, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement: Schritt 6, Bild 2 von 2
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 10-40, Amido Fall 2014 Mitglied von Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
Where do you purchase the replacement fan motors from?
mattb - Antwort
Do you know where I can find the fan motor replacement?
Dave Smith - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 6,382
