Zum Hauptinhalt wechseln
Honeywell HY-204 Rotation Button Replacement
Was du brauchst
  1. Honeywell HY-204 Rotation Button Replacement, Case: Schritt 1, Bild 1 von 2 Honeywell HY-204 Rotation Button Replacement, Case: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Rotation Button Replacement: Schritt 2, Bild 1 von 2 Honeywell HY-204 Rotation Button Replacement: Schritt 2, Bild 2 von 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Rotation Button Replacement, Control Panel: Schritt 3, Bild 1 von 2 Honeywell HY-204 Rotation Button Replacement, Control Panel: Schritt 3, Bild 2 von 2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Button Replacement: Schritt 4, Bild 1 von 1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
  5. Honeywell HY-204 Rotation Button Replacement, Rotation Button: Schritt 5, Bild 1 von 2 Honeywell HY-204 Rotation Button Replacement, Rotation Button: Schritt 5, Bild 2 von 2
    • Remove the two 10mm Phillips #0 screws that are located next to the rotation button.
  6. Honeywell HY-204 Rotation Button Replacement: Schritt 6, Bild 1 von 1
    • Peel back the heat shrink tubing on both wires connecting to the button.
  7. Honeywell HY-204 Rotation Button Replacement: Schritt 7, Bild 1 von 1
    • Caution The soldering iron is very hot, be careful to avoid burns.
    • Desolder the two wires connected to the button and remove the button.
Abschluss
Nolan Ernotte
384 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-40, Amido Fall 2014 Mitglied von Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 987
