Einleitung
Follow this guide to remove or repair any of the parts related to the front panel.
Was du brauchst
Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
Twist the fan base counter-clockwise until the pins line up as shown.
Pull the base straight towards you to remove it, feeding the wire through the base.
Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
Remove the two marked 3/4" Phillips #02 screws in the middle.
Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
Remove the four 1/2" Phillips #02 screws, indicated by a red circle.
Lean the front panel forwards and set it down.
Remove the four 1/2" Phillips #01 screws in the circuit board.
Gently pull the circuit board off of the rest of the front panel assembly.
If necessary, remove the buttons by grabbing them with two fingers and pulling up and away from the panel.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
the piece to make it turn is broken
the piece that make it turn is broken!
