Einleitung
If your Honeywell Turboforce Air Circulator is not working when you turn the device on, you may have a dead motor which needs replacing. Our guide will help show you how to properly remove the dead motor.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a Phillips #1 screwdriver, remove the six 15mm screws on the outer ring of the back of the fan holding the frame together.
Remove the two 36mm screws on the metal plate behind the blades using the Phillips #1 screwdriver.
Carefully pull the motor forward out of its resting position and tilt it forward revealing the back of the motor.
Using the Phillips #1 screwdriver, remove the two 37mm screws on the back of the motor.
3 weitere Nutzer haben diese Anleitung absolviert.
