Zum Hauptinhalt wechseln
  1. 700 w cyclonic hoover 700 w cyclonic hoover
    • 700 w cyclonic hoover
  2. The active carbon filter is totally blocked. Air cannot flow !!! The active carbon filter is totally blocked. Air cannot flow !!! The active carbon filter is totally blocked. Air cannot flow !!!
    • The active carbon filter is totally blocked. Air cannot flow !!!
  3. Using a screwdriver and a cutter is almost simple to remove the filter. Using a screwdriver and a cutter is almost simple to remove the filter. Using a screwdriver and a cutter is almost simple to remove the filter.
    • Using a screwdriver and a cutter is almost simple to remove the filter.
  4. Metal grid Foam Gauze
    • Metal grid
    • Foam
    • Gauze
  5. Cut the metal grid and place it. Place the gauze  (just a couple of sheets) over the grid.
    • Cut the metal grid and place it.
    • Place the gauze (just a couple of sheets) over the grid.
    • Cut and place the foam on top of the gauze.
  6. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  7. Insert wisdom here. Insert wisdom here. Insert wisdom here.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Carlo Romagnoli
275 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 10
Insgesamt: 384
