Einleitung
This guide will show you how to replace the internal switch inside the handle. This guide will be identical to the motherboard guide with a few extra steps. This would be needed if the power button is no longer working in the handle.
Was du brauchst
Remove the single 15mm Phillips #1 screw from the handle.
Remove the black rubber cover from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
