Zum Hauptinhalt wechseln
Hoover Power Path Deluxe FH50951 Brush Roll Replacement
Was du brauchst
  1. Hoover Power Path Deluxe FH50951 Brush Roll Replacement, Brush Roll: Schritt 1, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Brush Roll Replacement, Brush Roll: Schritt 1, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Brush Roll Replacement, Brush Roll: Schritt 1, Bild 3 von 3
    • Remove the four 18.6 mm screws labeled 1-4 using a Phillips #1 screwdriver.
    • Remove the piece that was being held down by those screws.
  2. Hoover Power Path Deluxe FH50951 Brush Roll Replacement: Schritt 2, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Brush Roll Replacement: Schritt 2, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Brush Roll Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 18.6 mm screws with arrows listing 5-8 using a Phillips #1 screwdriver.
    • Remove the wheel assembly on the left side of the vacuum.
    • You may need a longer Phillips #1 screwdriver for screw #7.
  3. Hoover Power Path Deluxe FH50951 Brush Roll Replacement: Schritt 3, Bild 1 von 1
    • Lift up the belt to give enough slack to allow the brush roll to come out.
    • While lifting the belt, pull/push upward away from the cleaner to pop it out.
    • It may seem like the brush rolls wont come out but just put more force into it.
Abschluss
Trevor Yaroslaski
281 Reputation
2 Anleitungen geschrieben
Cuesta, Team 60-1, Krynen Fall 2024 Mitglied von Cuesta, Team 60-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 32
