Einleitung
The power switch allows the Hoover Power Path Pro Advanced to turn on with the press of the power button. A defective power switch will not allow the user to control the on and off state of the device and needs to be replaced.
Was du brauchst
Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
Push down on the handle release button. Lift the edge of top cover connected to this button.
Repeat the above step for the "On/Off" button.
Pull entire top cover off.
Use a long #2 Philips head to remove the two screws from the arched grey piece.
4 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
What is the part number?
Thanks so much!!
