Einleitung
The suction motor is at the core of the proper function of any household floor cleaner. This guide will demonstrate how to properly replace a broken suction motor.
Was du brauchst
Lay the cleaner down horizontally with its wheels closest to the floor.
Hold the lower brush roll with both hands and pull outwards until it is detached.
Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
Remove the brush roller.
Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
Repeat the above step for the "On/Off" button.
Unscrew two screws using Phillips #2 screwdriver.
Detach grey piece from vacuum.
4 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
