Einleitung
Brushes that clean using the solution/water. These brushes may need to be cleaned after usage and need to be detached in order to clean.
Was du brauchst
Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out.
Using the screwdriver, unscrew both of the screws on the backside of the handle.
Pull the handle upwards. It should freely slide away from the base of the machine.
With the vacuum laying on its back pull gently on the brush part and wiggle until it pulls out of place. Now the brushes are ready for cleaning.
