Einleitung
This Guide shows you how to replace the handle.
Was du brauchst
Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out.
Using the screwdriver, unscrew both of the screws on the backside of the handle.
Pull the handle upwards. It should freely slide away from the base of the machine.
Fast fertig!
Abschluss
