Was du brauchst
Remove the hose solution connector from its port by pulling up away from the base gently.
Twist the hose tube connector counterclockwise from the “lock” to “unlocked” symbol.
Remove the hose tube from the hose port by pulling up away from the base gently.
Fast fertig!
Abschluss
