Zum Hauptinhalt wechseln
Hoover Presto 2-in-1 Cordless Stick Charger Replacement
Was du brauchst
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: Schritt 1, Bild 1 von 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: Schritt 1, Bild 2 von 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: Schritt 1, Bild 3 von 3
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 2, Bild 1 von 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 2, Bild 2 von 2
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 3, Bild 1 von 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 3, Bild 2 von 2
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 4, Bild 1 von 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 4, Bild 2 von 2
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 5, Bild 1 von 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 5, Bild 2 von 2
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 7, Bild 1 von 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: Schritt 7, Bild 2 von 2
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
katia zubieta
437 Reputation
4 Anleitungen geschrieben
CSU Fullerton, Team S2-G6, Bruce Fall 2017 Mitglied von CSU Fullerton, Team S2-G6, Bruce Fall 2017
CSUF-BRUCE-F17S2G6
3 Mitglieder
8 Anleitungen geschrieben
4 Kommentare
La pila dónde la puedo encontrar
alejandro rodriguez - Antwort
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - Antwort
Where does one buy the replacement battery?
mytikikitty - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 6,085
