Einleitung
The Hoover Presto 2-in-1 Cordless Stick's charger can have a poor battery life which may affect the battery life of your vacuum. This guide will provide steps on how to access the charger for replacement or troubleshooting.
Was du brauchst
Using a firm grip, gently pull the standing charger away from the floor charger attachment
Flip the floor charger over so the screws and sticker are facing you
Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
Using the metal spudger, gently pry open the two halves of the floor charger
Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
La pila dónde la puedo encontrar
De la aspiradora Hoover presto 2 un 1
Where does one buy the replacement battery?
