Einleitung
This guide is for the Hoover Rogue 970 (Model BH70970) Smart Vacuum.
Are your Hoover Rouge 970 wheels stuck, unable to rotate, or preventing the whole vacuum from moving? If so, here is the guide to fix the problem with a simple change of the wheels.
Was du brauchst
Press the buttons on the brush roll cover inward.
Gently pull the brush roll cover away from the vacuum.
Flip the vacuum over so that the underside is facing up.
Remove the fifteen 9.3 mm screws from the bottom frame with a Phillips #0 screwdriver.
Lift the bottom frame away from the vacuum.
Flip the device over so that the top side of the vacuum is facing up.
Firmly pull the silver face-plate away from the vacuum.
Remove four 8.7 mm screws using a Phillips #0 screwdriver.
Pull the top cover with the 'Hoover Rogue' markings away from the vacuum.
Remove the eight 15.8 mm screws from the vacuum using a Phillips #0 screwdriver.
Gently pry along seam with an iFixit opening tool in order to break the glue seals.
Firmly grasp the top and bottom portions of the vacuum with each thumb exerting pressure in opposite directions.
Disconnect the motherboard from the base assembly.
Locate wheel assembly.
Remove the five 8.7 mm screws using a Phillips #0 screwdriver.
Lift the wheel assembly out of the vacuum to access the white bundled cable connector connected to the circuit board.
Disconnect the white bundled cable connector that connects the wheel assembly to the circuit board.
Lift the disconnected wheel assembly away from vacuum.
