Einleitung
Use this guide to replace the brush in the head of the vacuum.
  1. Place the vacuum on its back.
    • Place the vacuum on its back.
    • On the bottom right side, push the red lever to the left.
    • Remove the plastic cover.
  2. Grab the red switch under the brush and push left.
    • Grab the red switch under the brush and push left.
    • Then remove the plastic base plate.
    • Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
    • Remove the two screws on the left side of the brush.
    • Pull the clear plastic away from the head of the vacuum.
    • Slide the belt off the metal rod with your finger.
    • Pull the brush free.
Abschluss
Erik Ingels
Mitglied seit 18.01.2018
193 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S12-G4, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G4, Banghart Winter 2018
CPSU-BANGHART-W18S12G4
5 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 56
