Einleitung
The motor is the most important part of the vacuum as without it, the vacuum cannot create suction. This is a walkthrough on how to replace the motor.
Was du brauchst
Next, remove the hose from the connector, near the top of the vacuum's rear. This can be achieved by twisting and then pulling down.
Use a Phillips #1 screwdriver to remove the two screws on the part holding the hose to the back of the vacuum.
Use a Phillips #1 screwdriver to remove the two screws that secure the hose-release tab.
Use a Phillips #1 screwdriver to remove the two screws on the top of the vacuum holding the tab on the left of the vacuum.
Use a Phillips #1 screwdriver to remove the two screws on the top of the vacuum head holding down the tab on the right.
To remove the tab, slide backwards and then pull up. There is a tab holding the piece down so use force if necessary.
Slide the belt off of the metal rod on the left of the vacuum shaft. Pull the vacuum up and it should easily separate into two pieces.
Use a Phillips #1 screwdriver to remove the 6 screws on the back and bottom of the vacuum shaft.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
