Einleitung
This guide will help you remove the belt the drives the brush.
Was du brauchst
Place the vacuum on its back.
On the bottom right side, push the red lever to the left.
Remove the plastic cover.
Grab the red switch under the brush and push left.
Then remove the plastic base plate.
Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
Pull the clear plastic away from the head of the vacuum.
Slide the belt off the metal rod with your finger.
Pull the brush free.
