Einleitung
This guide is intended to help you replace the brush roll on your vacuum. Please see the troubleshooting guide to determine if this needs replacement. Begin this step with the vacuum unplugged, and laying on the floor with the bottom facing towards you.
Werkzeuge
Ersatzteile
  1. Push the red release lever to the right. Turn the red switch counterclockwise. Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Pull brush roll out of vacuum.
    • Pull brush roll out of vacuum.
    • Remove belt from brush roller
Abschluss
Sophia Stockburger
530 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S11-G2, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Mitglieder
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Antwort
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 19
Insgesamt: 197
