Zum Hauptinhalt wechseln
Einleitung
This guide is intended to help you replace the brush roll on your vacuum. Please see the troubleshooting guide to determine if this needs replacement. Begin this step with the vacuum unplugged, and laying on the floor with the bottom facing towards you.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: Schritt 1, Bild 1 von 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: Schritt 1, Bild 2 von 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: Schritt 1, Bild 3 von 3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: Schritt 2, Bild 1 von 1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
Abschluss
Cal Poly, Team S11-G2, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Mitglieder
9 Anleitungen geschrieben
3 Kommentare
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Antwort
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 9
Insgesamt: 699
