Zum Hauptinhalt wechseln
Einleitung
This filter is located at the top of the vacuum. The filter should not be replaced unless visibly worn, or older than 6 months. If neither case is true, simply empty the dust into the trash and put the filter back in place. DO NOT clean with water. This step should begin with the vacuum unplugged.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Hoover T-Series WindTunnel Pet UH70102 HEPA Filter Replacement, HEPA Filter: Schritt 1, Bild 1 von 2 Hoover T-Series WindTunnel Pet UH70102 HEPA Filter Replacement, HEPA Filter: Schritt 1, Bild 2 von 2
    • Remove the filter by pressing on both indents and pulling away from the vacuum.
    • Clean the filter by gently tapping it on the edge of a garbage can. Replace the filter if it is damaged or is more than 6 months old.
Abschluss
Cal Poly, Team S11-G2, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
How do I replace the Hepa filter? It is older than 6 months but I can not find the replacement part
Julie Yearsley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 39
Insgesamt: 2,119
